enable vpls service
enable vpls [vpls_name | all] service
This command has been replaced with the following command: enable l2vpn [vpls [vpls_name | all] | vpws [vpws_name | all]] service .
This command is still supported for backward compatibility, but it will be removed from a future release, so we recommend that you start using the new command.
Description
Enables the configured VPLS services for the specified vpls_name.
Syntax Description
vpls_name Identifies the VPLS within the switch (character string).
all Specifies all VPLS.
Default
Enabled.
Usage Guidelines
This command enables the configured VPLS services for the specified vpls_name. When services are disabled, the VPLS is withdrawn from all peer sessions. The keyword all enables services for all VPLS instances.
The following command enables the configured VPLS services for the specified VPLS instance:
enable vpls myvpls service
This command was first available in ExtremeXOS 11.6.
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
